Long distance
Kammi
When I try to call long distance it says that my minutes are used up…… I haven’t called any long distance numbers since I got this plan….. plan says I have long distance
slusagm
@Kammi  and @BKNS27
if the LD minutes are from the plan, not add-on, the list is much smaller
 monthly international long-distance minutes to China, Hong Kong, India, Pakistan, Philippines, Taiwan, and the UK³
So question to @Kammi
  1. are you talking about the monthly LD calling minutes that comes with the plan? or are you talking about the one time paid add-on you purchased?
  2. which country you are calling?
@Kammi
Did you purchase a LD add-on calling to these countries?
Some plans include LD to these countries:
 Here are countries you can purchase add-on for LD calling:
 Is the country you are calling on the list options?
slusagm
where you are trying to call? those Long distance minutes that come with the plan can only call some countries but not all
