Long Distance
Robr75
I just purchased a Canada-US-Mexico plan yesterday and made a call to the US
I get a recording at the beginning saying this call can be subject to long distance charges
Why is this happening. I thought long distance calls were included in the plan
Robr75
Thank you. It works
SeeS
Did you dial 1-Areacode-Number?     need to add in the country code.
or you might have to dial  +1-areacode-number.  Put in the "+"
porcupine
They are included in the plan i would ignore that
