12-28-2018 07:47 PM - edited 01-05-2022 06:23 AM
I registered my mobile with email ID ([email protected]) however couldn't login. it shows email is not recognized.
12-29-2018 08:38 AM
please send a private message to the Moderator_Team account using the envelope icon in the upper right corner of every community page.
Please provide your issue for them, and they will contact back via Private Message with further instructions.
12-28-2018 08:06 PM - edited 12-28-2018 08:06 PM
You mean you activated with that email and now you are not able to login? Are you sure you typed the correct email? Try resetting the password here: https://selfserve.publicmobile.ca/forgot-password/
