Locked out of my account
Rob042
How do I fix, it says contact public mobile, how?
2 REPLIES 2
@HALIMACS wrote:
Send a private message to the moderator by clicking here
While waiting them to respond, you might also wait one full hour before trying again, clear cache & cookies, open an incognito tab, then try again.
For information purposes, SIMon should still be used for resetting a self serve password. I know that the ticketing process does usually ask for self serve credentials, but when the option is slected for a forgotten password, the ticketing system will then ask the customer for the account PIN instead.
HALIMACS
