04-07-2019 03:52 PM - edited 01-05-2022 04:13 AM
How long does it usually take to port a number and cancel your old/ pre-exisiting phone plan?
04-07-2019 04:36 PM
The process takes less than 2 hours in most cases if it is a mobile number being ported.
For landline numbers/VOIP, the transfer will take between 1-2 weeks.
In either case, you will get a text message confirmation when the transfer is complete, and the old account will be cancelled automatically. The most important thing to ensure is that you put your account number or PIN number correctly when you are submitting the porting request, since this is most likely the only thing that will go wrong.
04-07-2019 04:33 PM
Thanks @Pizzaeh for those two web pages: very complete information from a totally credible source. Could not ask for more !
04-07-2019 04:30 PM
@JaimeLaPizza you can read about it in the following links...
CRTC: Switch providers and keep your number.
Canadian Wireless Telecommunications Association (CWTA): Wireless Number Portability.
04-07-2019 04:20 PM
I just ported my wife # from Koodo, it only took 1 min. And everything work after I got the cancellation email from Koodo.
04-07-2019 04:08 PM
@Pizzaeh thanks for pointing that the account at the current service provider must not be cancelled if one wants to port their number to their new service provider. You are right, do not cancel before porting ! However, in my post I was refering to cancelling after porting, which you say is not needed. OK ! ![]()
04-07-2019 04:02 PM
@JaimeLaPizza when a number is ported out from another carrier, that automatically cancels the line with the old carrier. The old carrier should not be called to cancel the line; the line must be active with the other carrier to be ported to a new carrier.
04-07-2019 03:59 PM
For me it was about 2 hours. Before that I could call but when people called me it ended up in my previous voice mail box. You will receive an SMS when it all completed. I had forgotten to cancel my plan with my previous service provider, but when I called a few days later, the person told me that my account had been closed (it was as if porting had caused the account to be cancelled, which would seem logical). However, I would recommend to call anyways and make sure everything is cancelled because the person told me to watch my next credit card statement to make sure my pre-authorized payment have also been cancelled !
04-07-2019 03:58 PM
@disneybear15 it can take up to 48 hours to complete.
