10-30-2016 01:02 PM - edited 01-04-2022 01:05 PM
07-17-2017 11:56 AM
Hi,
I also ran into this issue when I was setting up my LG G4 with PM.
The backing up and restore was fine for me, however,the restore did not fix my data issues.
I ended up doing a Network reset and that fixed my issues.
The only annoying part of the factory re-store is that you have to set up all your accounts on the phone (I have multiple email addresses) and also you have to make sure your contacts are backed up to google if not you will only see the phone numbers and no way of identifying them.
I would advise you to do the Network reset first instead of doing the Factory Reset right the way.
To do the network reset go to:
Settings > General > Backup & reset > Network settings reset
and reset your network settings then re-start your phone
That worked for me
10-31-2016 12:21 PM
@rolomonster funny how things work out some times, eh?
10-31-2016 09:22 AM
10-30-2016 07:33 PM
Happy to hear you got data working.
What exactly did the trick in the end?
10-30-2016 07:24 PM
10-30-2016 06:17 PM
Sorry, I have been out for the last few hours so couldn't reply.
My APN settings have just one modification. In the "APN type" instead of leaving blank, I have "default,mms,supl"
The rest of the lines are the same as those in the "Knowledge Base" section of this community.
Any progress since that last post?
10-30-2016 03:44 PM
10-30-2016 03:09 PM
I clicked into the APN settings I set up so there is a green dot. SMS and calls do work. Network is on auto but even when I search all my available network stuff say Telus, Bell, or Wind... Looks like all options such as LTE and WCIMA are all there from each of the networks. Nothing next to signal cluster.
10-30-2016 03:02 PM - edited 10-30-2016 03:04 PM
Does a green dot appear next to the APN?
Is your call/sms working? Does the selfserve indicate your selected plan?
Does LTE and/or 4G/H+ show next to the signal cluster in the status bar?
What about preferred network type in mobile networks settings. Is is on auto LTE/WCDMA/GSM?
Toggle the airplane mode on-off.
Sorry to hear it didn't work, I personally deal with 3 G4's among family and friends and the factory data reset helped us over the last year of travelling and swapping sims.
EDIT: Saray must have a backlog of requests. She will respond as soon as she can. Maybe a refresh of your account from their end will help. Wish you a speedy resolution.
10-30-2016 02:52 PM
10-30-2016 02:21 PM
Great info, @imm1304--thanks for helping out 🙂
10-30-2016 02:17 PM - edited 10-30-2016 02:19 PM
Hi @rolomonster, I second @srlawren's suggestion.
As a fellow G4 user, I have seen and helped others go thorugh all sorts of troubleshooting steps but eventually it was the factory reset that fixed it. Its not exclusive to PM, any carrier change causes trouble for some of the G4's (not all).
So, backup your important files/pics etc on a computer or an sd card first. LG Backup app on your phone is great for backing up to the sd card and provides an easy restore later.
If you can't find the LG backup app in the app drawer, in the newer software, its baked into the system and can be accessed from Settings >> General >> Backup & Reset >> LG Backup
10-30-2016 02:11 PM
@rolomonster this has come up a number of times in the past for G4 and the only solution was a factory reset. Please back up anything you want to keep that's not sync'd to the cloud first, and then do the factory reset. This will get you up and running.
10-30-2016 01:49 PM
click on their name saray is online i believe @Saray_O
10-30-2016 01:43 PM
Tried. Didn't work. How can I contact a mod?
10-30-2016 01:05 PM
hi..
here's a link for troubleshooting LG no data issues...:
http://www.thecellguide.com/lgnodata.php
if nothing works i guess a factory reset might need to be done....but before i would conatc 1 of the moderators to make sure all is fine on the account side.....
