11-24-2023 10:56 AM - last edited on 11-25-2023 02:39 AM by computergeek541
Hi,
I'm having troubles transferring my Koodo phone number, hoping a @CS_Agent is able to assist.
Thanks,
Klay
11-24-2023 11:02 AM
Is that Koodo pre-paid or post-paid? You should be able to do a normal transfer with post-paid. You would need support for pre-paid. Support can be contacted here:
11-24-2023 10:59 AM
@Klay Customer service is available at the following link:
I'll message you a number for porting help. Check your messages.
