05-25-2020 02:13 AM - edited 01-05-2022 10:53 AM
Does PM have a server on discord too? Also how likely will they have a mobile app?
It's not very user friendly to view my account on my phone.
Joining Public
05-25-2020 09:51 PM
05-25-2020 09:19 PM - edited 05-25-2020 09:27 PM
@ibuddler wrote:When I dial 611 from my phone, will it use my airtime?
Thanks,
No, it will not.
Edit: If you are on the $15 plan, using you phone to check voicemail will use up out going minutes. You can dial your number from another phone and at the greeting press * to get into your voicemail.
Another option suggested by @gblackma is:
I'm on the same plan and to save more, add the TextNow voip app and use it via Wifi to make / receive / send calls and texts in Canada and to the United States for free. You can also use it as I do to check my voicemail from my own phone without using the minutes from the PM plan. Simply dial your PM phone number - reject the call when it rings (this sends the call to voicemail) - press the * key to allow you to enter your password. - enter - and you are in your voicemail account - Hang up when you are finished. No minutes used.
Stay safe.
05-25-2020 09:09 PM
Thanks,
05-25-2020 12:13 PM - edited 05-25-2020 12:13 PM
@ibuddler , Public Mobile have twitter and facebook accounts. I am not aware of any discord account. I use discord and have not received any invites anyway.
05-25-2020 12:01 PM - edited 05-25-2020 12:41 PM
05-25-2020 09:55 AM
if you want to feel like you are clicking on an app go to your browser settings for this page and make a home screen icon.
Here is what it looks like.
05-25-2020 02:49 AM
I Use PM website on my small Phone, iPhone SE works well, created a home screen window, works great.
05-25-2020 02:32 AM
@dougc wrote:If you can access the internet on your mobile, there is no need for an app'.
IMHO !
p.s. especially considering all the permissions/access that people tend to giveaway to the true overseers of the app' !
As for app permisions, I'm sure that the things that the web browser is programmed to have access to can be quite shocking too. When it comes to mobile carrier apps, they have often just been nothing more than a standalone bookmark that load the mobile version of the website anyway.
05-25-2020 02:27 AM
IMHO !
05-25-2020 02:23 AM - edited 05-25-2020 02:32 AM
@ibuddler I don't think PM will provide mobile app.
But there is an app called Data Witness PM written by a PM subscriber to monitor data usage for 30 and 90 days plan.
https://play.google.com/store/apps/details?id=com.iwik.datawitnesspm&hl=en_CA
05-25-2020 02:16 AM
@ibuddler wrote:Does PM have a server on discord too? Also how likely will they have a mobile app?
This Community website is the only official messaging forum for Public Mobile. While, there are certainly chat rooms on Discord that people talk about Public Mobile in, there is no official Public Mobile prescece there.
