09-14-2020 08:20 PM - edited 01-05-2022 03:53 PM
I have been with Public Mobile for almost a year and I have yet to successfully open a voicemail. I have tried everything.. (reseting network, rebooting phone, resetting voicemail password) help please!
09-14-2020 10:55 PM
09-14-2020 10:46 PM
@communityWendy if you have parental control enabled for address book, because voicemail isn't in your address book you need to allow communication with 'everyone' in order for the voicemail to work.
09-14-2020 10:27 PM
@communityWendy wrote:I have been with Public Mobile for almost a year and I have yet to successfully open a voicemail. I have tried everything.. (reseting network, rebooting phone, resetting voicemail password) help please!
Hi @communityWendy , if you are still trying to set up voicemail on your iphone 6s, check out this link How to Set Up Voicemail on Your iPhone . I hope this helps. Come back and let us know. Cheers! 😊
09-14-2020 10:03 PM - edited 09-14-2020 10:04 PM
If all else fails and you can't figure out the correct voicemail retrieval number, set up the voice mailbox up or check your messages by dialing your own phone number.
09-14-2020 08:48 PM - edited 09-14-2020 08:49 PM
Okay...Try these steps. Check your Visual Voicemail after each step:
09-14-2020 08:35 PM
Sorry, I already seen that on troubleshooting. No luck but thanks for trying to help!!
09-14-2020 08:32 PM - edited 09-14-2020 08:34 PM
09-14-2020 08:25 PM
If you were to dial 17785804001 what do you get? If you have reset your voicemail password in the self-serve then the new password is your 10 digit phone number. Try that number I gave and then try that password and see what you get. It might even think you need to do initial set up.
