Internet connections
Padcorp
New phone LG D852
Android 6
No internet connection except  from WiFi
Updated APN according to PM  specs
What can be done???
cavemantoronto
@Padcorp wrote:
New phone LG D852
Android 6
What can be done???
If you can't get Public Mobile to push a APN setting file to you or netowrk reset doesn't work, no other choice than to do a factory reset. LG is known for this. Before, factory reset back up your stuff or you'll lose it.
popping
@Padcorp wrote:
New phone LG D852
Android 6
What can be done???
For LG phone, you need to do a network reset after changing provider before your LG phone data working again.
After network reset, enable data and restart your phone to let PM SIM card configure your APN automatically.
geopublic
@Padcorp wrote:
New phone LG D852
Android 6
What can be done???
@Padcorp  Try resetting your network settings:
  1. Touch Settings
  2. Touch System
  3. Touch Restart & Reset
  4. Touch Network settings reset
  5. Touch RESET SETTINGS
Jb456
Post a screenshot of the APN settings you have or double check them .
Should be like this.
 if they don't work try the below.
Remember after adding the APN settings reboot phone.
Let us know.
