12-04-2020 04:39 PM - edited 01-05-2022 05:38 PM
Hi there, my plan includes international texting. However, it won't go through when I send text and picture message to China or Taiwan. I've topped up my account but it still doesn't work. I need your help!
12-21-2020 07:01 PM
@EllaLin2018 wrote:Hi there, my plan includes international texting. However, it won't go through when I send text and picture message to China or Taiwan. I've topped up my account but it still doesn't work. I need your help!
@EllaLin2018 hi there. I think for China it would be 011-86-Area code- phone number
Happy Holidays! 🎄🎄🎄
12-21-2020 07:01 PM
@EllaLin2018 wrote:No. I use country code + mobile number.
Re-read an earlier post...you _need_ to use 011 (or just +) to "get out of North America". Then you use the country code to "get into that country". Then the rest of the area code and individual number. Sometimes country codes show a leading zero. Try without if the country you're trying to dial has one in references you're finding.
12-21-2020 06:53 PM
No. Even the text message won't go through.
12-21-2020 06:53 PM
12-04-2020 05:59 PM
depends on the country, sometimes the way you put in the number matters.. make sure you have the correct pattern.
12-04-2020 05:33 PM
If it is only MMS or pictures that are not working, try reducing the size being sent, and see if that works.
12-04-2020 04:45 PM
Does a text by itself without the pictures go through?
12-04-2020 04:41 PM - edited 12-04-2020 04:42 PM
@EllaLin2018 Are you using the international access + sign (or alternatively 011) followed by country code etc?
