Incomplete Port
03-18-2019 11:19 PM - edited 01-05-2022 06:55 AM
It has been at least 4 hours and my old phone number has not ported out completely. I am switching from an old phone with a Petro Mobility SIM to a new phone with a Public Mobile SIM.
With the new phone (public mobile) I am able to make texts and calls, all of which show the ported number. However, any incoming calls/texts to the ported number go to the old phone (with Petro Mobility sim). What can be done to fix this? @Moderator_Team
Service
03-19-2019 07:49 AM
It's working now. Thanks! I think it just needed a lot more time.
03-19-2019 12:19 AM
Why would you call to get an imei number? Settings, about phone, status, imei info (android)
@popping wrote:
@CWMinnie wrote:It has been at least 4 hours and my old phone number has not ported out completely. I am switching from an old phone with a Petro Mobility SIM to a new phone with a Public Mobile SIM.
Did you call Petro Mobility to get your IMEI number on your file at Petro Mobility?
If not, call them to get it
Send a private message to moderator with your name, your phone number and IMEI number in order to port from Petro Mobility.
03-18-2019 11:27 PM
03-18-2019 11:25 PM
@CWMinnie send a private message to moderator_team with your porting info. you might also get a call on the alternate number you provided (from telus porting team) and they will ask to verify your porting info.
03-18-2019 11:24 PM
@CWMinnie - It could be that the port is simply taking longer that usual. That said, when a port fails, you should get a message advising you to contact support. If you need to get in touch with the moderator team, you are better off sending them a private message.
Click here to send the moderator team a private message. Their hours are: Mon-Fri 8AM-Midnight(EST) & Sat/Sun 8AM-10:00PM(EST)
You can find information regarding the moderator team by following this link.
