06-07-2022 01:07 AM
Hi,
Kindly refund my last amount charged for 20$ with tax 22$ it was charged wrongly.
I can't use US roaming international min.
Moreover the network is pathetic. Data is so less and so costly in public.
Extremely unhappy with services.
06-07-2022 10:17 PM
@nirmalayadav - if you still see the funds in your Available Funds area, then you did not successfully add the addon to your account. Those funds will be used first on future renewals, so you can leave the $'s there.
Otherwise, if the addons were added successfully to your account, see method to contact CSA as already provided.
For roaming information, see a Get Help article here: https://www.publicmobile.ca/en/bc/get-help/articles/us-roaming#:~:text=Troubleshooting%20U.S.%20Roam...
06-07-2022 02:09 AM
Click on the link supplied by @computergeek541 but please note their hours are 6:00am to 10:00pm EST.
06-07-2022 02:00 AM
@JL9 wrote:You can click on the envelope in the top right of your screen and private message CS_Agent.
Customer support agents are to be contact by using the official ticketing process at https://widget.telus.tiia.ai/publicmobile/publicmobile.html . The above mentioend method through private messaging is only there as a backup and will result in slower service/response.
06-07-2022 01:34 AM
If you are planning on continuing your PM service you may want to ask a CSA to just put the wrong add on charge back into your available balance for your next renewal or add ons. If you are going to another provider they may be able to process a refund depending on the circumstances
06-07-2022 01:33 AM
06-07-2022 01:28 AM
How to contact CS_agent?
06-07-2022 01:27 AM
I have recharged 15$ add on not 20$ this happened automatically because of auto populated amounts.
06-07-2022 01:25 AM
Did you purchase the wrong Add-on?
There are International calling to specific countries from Canada or US Roaming calling while you are in the US.
You will need to contact a CS_Agent if you purchased the wrong Add-on. It amount can stay in your account as credit or you can ask for a refund but will take up to 30 days to process.
06-07-2022 01:11 AM
@nirmalayadav wrote:Hi,
Whats the reason you are unable to use US minutes?
You should contact support agents for the refund.
