01-01-2017 05:59 PM - edited 01-05-2022 01:28 AM
I have registered 2 phone numbers with Public Mobile since early December 2016.
I am using the same credit card to AutoPay both phone numbers' 90-Days plan.
However, I can see only one of my phones is given the AutoPay reward - $6.
I want to know why?
01-12-2017 09:05 PM - edited 01-12-2017 09:07 PM
@dearmusic wrote:Dang! You referred 6 friends?
I wish I have 6 friends... #foreveralone...
If you are referrring to the first screenshot it would be two friends x $3 per 90 days
01-12-2017 08:21 PM - edited 01-12-2017 08:22 PM
01-01-2017 08:37 PM
Try removing the auto-pay and then adding it back. This way fixed my same problem before.
01-01-2017 06:34 PM
Click on my rewards to go into the rewards page. You should see a little blue triangle pointing right. Click on the triangle and a list below it will appear showing the numbers referred from your account. If the list is incomplete, contact a moderator for resolution.
As for how the rewards are issued for new accounts, it seems like if referrals are made very early after initial account activation, each referral yields $6 towards the next payment. Referrals made some time later seems to only yield $3 per referral. There must be a cutoff date on the switchover, not sure when though.
01-01-2017 06:29 PM
Hey @chj915,
Your AutoPay reward will kick in right before your next plan renewal date, when the payment goes through automatically for the first time 😛
01-01-2017 06:04 PM
Hi. It is known the system have some bugs. I guess you need moderator to input it manually for you. Just send a private message to one of the moderators and they will fix it for you. This is how you send private message :
