How to get my data connection back again
pabloguerrero
Hi.
I had to reset my phone to factory setting due to malfunctioning. Despite I kept track of what has to be input in the Access Point Names and was filled out as such, I have been able to get neither the network displayed nor the right performance of data streaming. Is there anywhere a list of those features to upload in the fields just in case I made a mistake?
2 REPLIES 2
Luddite
@pabloguerrero Still stuck?
APN Settings
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: default,supl,mms,DUN
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Especially no spaces in APN Type field: https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Calling-Texting-Data-work-fine-MMS-no...
 @pabloguerrero : Post screenshots of what you have and maybe an eagle eye here might spot something. Different set of eyes and all that.
Can you set networks to automatic? Or manually scan for here? Also check to make sure you're not on GSM. You want to be among LTE/WCDMA/UMTS/HSDPA/4G/3G.
