How to get data working on Galaxy
token
Hi would anyone know the best network settings for a samsung
galaxy S4 (SGH-M919) and a Galaxy S7 (SMG-930A).
Phone checker says both should be fine.
The S7 is spotty and the S4 doesn't seem to have data at all
but it is working with my Chatr line.
Also tried walking outside but no luck at all with S4
token
never worked since activation a month ago
srlawren
@popping wrote:
APN may still point to Chatr.
@popping possible!
@token you might need to set the CSC on either/both phone to Telus or Koodo to get it working properly.  I'm not an expert on doing this as I'm not a Samsung phone guy.  Maybe someone will reply here with more details.  If not, try searching the community for CSC.
EDIT: try this thread maybe?  https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Samsung-Galaxy-S4-No-LTE/m-p/128426#M... and this one?  https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Public-Mobile-has-their-own-CSC-code-...
ooakosiryan
If resetting your network settings and verifying your APN settings, as suggested by @ChuckYeah, doesn't work...something might've gone wrong when activating your SIM, especially with your S4—if it works with Chatr but not PM I think it's not a settings thing. (has it worked before with PM but then stopped, or is it newly activated and never worked?)
If something went wrong, the Mods might be able to fix it for you. Submit a ticket through SIMon by clicking the question mark thing at the bottom right. It can take anywhere from a couple hours to a couple days for a response.
Good luck! Hope you get it sorted!
popping
Enable data on you S4 and restart your phone to get PM SIM card to configure your APN automatically.  If not, you may need to set up your APN manually with @ChuckYeah info.
ChuckYeah
Try resetting the network settings with data enabled and reboot the phone. Check your APN settings as well.
If Android, click:
Settings > More / More Networks / Wireless & Networks > Mobile/Cellular Networks > Access Point Names >
These are mine:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
