09-19-2024 01:46 AM - last edited on 09-19-2024 04:27 PM by computergeek541
WI sure would like to know how much data I have left at any given time. It’s September 19. In my Public Mobile app, it shows 1.56 of 50 GB used, “Last updated Aug 18”. This is useless, I’ve used much more than that. How can I know where I am in my usage at any time I check, with up to date figures????
09-19-2024 05:01 PM
self solution removed
09-19-2024 04:48 PM
Issue has been resolved, refresh in app worked, tyvm all
09-19-2024 07:38 AM - edited 09-19-2024 08:45 AM
@rollme1kenobi On my Android phone in the app, I pull down on the main/usage screen and it will update it.
09-19-2024 07:07 AM
@rollme1kenobi I can see you are using the app already and not the browser
Try to logout the PM app and re-login and you will see the updated usage
Worst case, uninstall and reinstall PM app
09-19-2024 04:19 AM
Clear the cache on your browser before login to your account online or login on the PM app.
