06-04-2017 03:41 PM - edited 01-04-2022 01:50 PM
06-04-2017 05:31 PM
06-04-2017 05:19 PM
@Samianauman If you early renew or reset your billing cycle, you may get your data reset but wouldn't you lose the money you had paid for the end of original billing cycle?
06-04-2017 05:03 PM
@Samianauman wrote:
Agreed with willam
We had few earlier post from other op. It won't reset automatically or just to top up if you need data and renewal is close by and you don't mind early renewal then contact mod they can manually reset your plan for you.
I agree with @Samianauman for agreeing with me. ![]()
06-04-2017 04:28 PM
06-04-2017 04:04 PM - edited 06-04-2017 04:08 PM
@Carlos3, yes you can early renew your current plan to get more data. You need a moderator to do it for you. If you have never contacted a moderator before, refer to the following links for information on private messaging and how to contact a moderator.
http://productioncommunity.publicmobile.ca/t5/Getting-Started/Private-Messages-viewing-and-creating/...
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
Here's the link discussing the workaround that only a moderator can do to make it happen.
06-04-2017 03:43 PM
@Carlos3, I don't think you can just reset your data limit during your billing cycle. If you ran out of data and need more, you can always buy a data add on.
