How do I personalize a plan?
LittleZee
Hi I am wondering if I can personalize a plan to include the following 3 things for $30.00/month or less??:
1. unlimited local/provincial calling
2. Unlimited text messaging
3. Voicemail and call display
Or if this isn't possible, can I add unlimited text messaging to the $20.00/month plan?
LittleZee
Ended upgeup get the $30/month plan... it's the best plan for what I need. Thanks for your help!
will13am
@LittleZee, the plan you want will cost $25 per month using the plan builder option.  Most often, the best pricing comes from getting a so called ready made plan.  I suggest you look at getting the $30 ready made plan that comes with unlimited Canada wide calling, international text, 1GB of data.  Getting this plan would qualify you for this promotion.
https://productioncommunity.publicmobile.ca/t5/Announcements/Activate-any-30-mo-plan-and-get-10-off-...
With the $10 monthly credit for 6 months, your cost will actually be less at $20 per month.  You will need to pay $30 for the first month before the credits are applied in months 2 to 7.  Overall, your cost will be less for the 7 months.  At that time, you can decide whether you want to stick with the plan or pay $5 less and downgrade to the features that you exactly want.
Separately, you can seek a referral and take advantage of this ongoing deal.  This will give you an extra one time $25 account credit.  You must activate online obtain this offer.
https://productioncommunity.publicmobile.ca/t5/Announcements/Share-the-love-get-a-25-Credit-for-You-...
cavemantoronto
This plan costs $25 at Public Mobile for all 3 in your list.
CS_Agent
Hello LittleZee
Thank's for getting in touch with us.
Yes you can select the features that you would like.
Here I'll send you the link so you can take a look.
https://www.publicmobile.ca/en/bc/plans
You'll see the option bellow that says 'build your own paln'
Kind Regards,
Rod,
Public Mobile Moderator Team.
Lieux
You can buy add-on but not with  texts...just calls...
Lieux
Yes you have this plan for 25$ per month...here you can check...
https://www.publicmobile.ca/en/bc/plans/25unlimitedtalk-text
@LittleZee
