How do I get two numbers moved?
Ted46
Applying to change from Rogers to Public, it says my Rogers account will be terminated when my number is moved to Public, but I have two lines on my Rogers account and want to keep the numbers for both. How do I do this?
Ted
1 REPLY 1
slusagm
Not to worry.  You Rogers account won't be closed if you just move one number away.  That warning just a default reminder
If you need to move 2 numbers, do it one at a time (and you need 2 different email addresses to open 2 different PM accounts to move both numbers). Once the Rogers account left with no numbers, when both numbers ported, it will then be closed
