How I can set up my puk code
Cathy1984
How find my puk code
Jeremy_M
Retraité / Retired
Retraité / Retired
Hi @Cathy1984
In order to get a PUK code you'll need to go to Contact Us and click "Email Away". This request is account specific, so our helpful team will need to respond to you directly in order to get you on your way.
Cheers!
Martin
Legend
Legend
Hello Cathy1984,
As chuk said, the self-serve account lacks the ability to create a PUK code.
If you need one, and became a customer prior to January 27, 2015, call *611 from your cell, or 1-855-4PUBLIC from any phone.
If you became a customer on or after January 27, 2015, you must communicate with Public Mobile by web mail only. Click Contact Us in the left column of the home page. A new page will open with Email Away on it. Click that, and another new page will open with a web form and a hyperlink called None of the above. Click None of the above, and submit it to Public Mobile.
Good luck!
chukdefatey
That's the one thing missing on PM self serve site
Cathy1984
