Hi
Waseem419
Hi i need selfservice account  activad
jlarocque96
Hey bro.
Check out the activate tab. You will need a new sim card. I just ordered mine in the mail. But to be honest don't do that. It took awhile to come in.
Someone else suggest Walmart ...that's the best idea.
1. Get the sim card.
2. In internet explorer browser go to public Mobile website
3. Activate.
4. Fill the form
5. If you have an old number click port number otherwise select the new number option.
6. Submit the application.
7. You should be good to go, Just insert the sim into your phone when you are done
There are more steps like billing and plans
But that's all self explanatory.
Good luck.
Waseem419
Hello yes you need account
Waseem419
Hello yes
mimmo
@Waseem419  the fist step is to get a sim card, walmart , wow mobile and k-moblie or order online.
from there you go to this page and activate it. everything here is do it yourself. https://activate.publicmobile.ca/
Luddite
Sorry, what do you mean? You have an account and need to login, or you want to create an account, or?
