Help
11-09-2016 01:03 PM - edited 01-04-2022 06:10 PM
Service
11-09-2016 08:13 PM
11-09-2016 08:12 PM
11-09-2016 03:27 PM
11-09-2016 01:35 PM
@Richardmawn wrote:
I reactivated my account my since reactivating it says every call is long distance and I can't send or receive texts or calls.. I'm paying for time I can't even use.. I have sent public mobile 2 emails and no response. . PLEASE HELP. it shows I'm on network and no reception problems... I hope I get credited the time I haven't been able to use my phone..
I heard that communicating via Twitter/Fcb get the anwser faster. You may try to contact them by Twitter/fcb. Hope it helps!
11-09-2016 01:08 PM
http://productioncommunity.publicmobile.ca/t5/Announcements/Information-required-before-sending-a-me...
Things that you can try is to create a brand new APN, restart phone.
Did you port your phone number?
11-09-2016 01:08 PM
Hi Richardmawn!
Welcome back to PM!
Please be advised the mods are currently inundated with support requests due to
the current promotion and some porting issues. While I know it's frustrating to
have issues, they will in fact respond to you as soon as they can. Just be a
little patient and hopefully they can resolve this for you soon!
I'll go ahead and tag @Shazia_K for you. You may also want to send them a PM to get you started:
Good luck!
