09-15-2018 10:02 AM - edited 01-05-2022 01:48 AM
Cant get incoming call it ring busy I can call out and text but people cant call me help
09-15-2018 11:21 AM
APN settings are for data plans. If you are only on a text and talk plan, normally, do not have to worry about APN settings.
Unless you want to sent pictures via text (MMS texts), then you will need to set up APN settings correctly.
09-15-2018 11:19 AM
What is the apn settings
09-15-2018 11:10 AM
A5 is a newer phone and should work. You might want to try network reset.
You will need to put your request in for moderator help if you have not done already. Again, 1-2 days waittimes for response.
Send a private message through the following link :
Please include in the private message your phone number, your account number and PIN code.
09-15-2018 11:02 AM
A5 2017 it work I am talk to on it just can get incoming calls
09-15-2018 10:53 AM
Have you tried re-booting your phone? Remove and re-insert your SiM? As mentioned above, try your sim in another phone. Which phone model do you have? It is possible that it might not be compatable with PM.
If that doesn't work, something went wrong with your activation of your new phone number. You will likely need to contact moderator. Wait times are 1-2 days for response....
09-15-2018 10:34 AM
@KMG wrote:
@mimmo wrote:
@KMG wrote:Did you just port your phone number over to Public Mobile? If so, it can take a day or so for the porting process to complete.
If it has been longer than that, you should contact the Moderator Team so that they can look into it.
@KMG I am pretty sure porting for cellular lines is 1-2 hours , landlines 24-48. Did you read otherwise?
Apparently "a few hours" for mobile numbers, whatever that means. For landlines, up to 2 business days.
https://crtc.gc.ca/eng/phone/mobile/num.htm
A few hours is like 2-3. A day has too many hours to be a few.
09-15-2018 10:24 AM
09-15-2018 10:22 AM
@SARAHMULDER4 wrote:I just join to public mobile last nite at 330 with a new number
Any way to try the sim in a different phone? That helps isolate hardware vs account issues.
09-15-2018 10:21 AM
09-15-2018 10:20 AM
09-15-2018 10:12 AM
@SARAHMULDER4 hi some additional info is needed.
did you just sign up? or old customer.
if new customer did you get a new number or did you port your number from old account
if you ported, did teh port complete? does your old sim still work?
typically working outgoing not working incoming is a sign of a failed port.
another possible option is you have a do not disturb/ call blocking feature on
09-15-2018 10:10 AM
