11-09-2020 12:16 PM - edited 01-05-2022 04:03 PM
Need help to access online account so that i can speak to someone as i can not send text messages
11-09-2020 02:39 PM - edited 11-09-2020 02:41 PM
@Terry4 wrote:All texts do it, including to myself
Please report what you find here:
In the texting app:
the 3 dots
Settings
More settings
Text messages
Message Centre
What number do you have there? Make sure it's set to +16475800172
This whole question also depends on whether you're on the old $10 plan. I doubt it. But gotta ask.
11-09-2020 02:24 PM
Can you download a texting app and see if it works?
11-09-2020 02:20 PM
11-09-2020 02:06 PM - edited 11-09-2020 02:07 PM
All texts or one specific number?
Can you text yourself? Just enter your cell number and hit send. It should come right back to you.
11-09-2020 02:05 PM
@Terry4 wrote:Yes i can make and receive voice calls. I can also receive text messages. i just can't send them.
Have you submitted a ticket to the moderators using one of the methods posted above.
11-09-2020 01:59 PM
I looked at that link already and did what they suggested but still no luck
11-09-2020 01:56 PM
11-09-2020 01:46 PM
@Terry4 wrote:I have a samsung galaxy s7 and it shows text message failed
Have a look at this article:
11-09-2020 01:44 PM
11-09-2020 12:32 PM
What brand of phone and model do you have?
Does data work?
11-09-2020 12:30 PM - edited 11-09-2020 12:31 PM
@Terry4 wrote:Need help to access online account so that i can speak to someone as i can not send text messages
Check this setting;
The SMSC needs to be set to +16475800172.
11-09-2020 12:28 PM - edited 11-09-2020 12:31 PM
@Terry4 Can you use your phone to make or receive voice calls? As others have indicated, it's possible your Message app may be set to iMessage or perhaps chat settings under Message settings need to be changed.
11-09-2020 12:27 PM
If you are using iMessage on your iPhone, you need to configure your iMessage enable sending/receiving text messages.
Under iPhone Messages settings:
iMessage = enabled
SMS/MMS
MMS Messaging = enabled
Group Messaging = enabled
All other Messages settings are disabled
How do you know what message type you are sending or receiving on iPhone?
Messages with green bubbles are normal SMS/MMS text messages.
Message with blue bubbles are sent via the iMessage
11-09-2020 12:23 PM
What happens when you try to send, does it tone out?
Are you trying to send mms or text? For mms you must turn on data.
Can you try different texting app?
Can you test your sim in different phone?
11-09-2020 12:19 PM - edited 11-09-2020 12:19 PM
Here’s how to contact the Moderator Team (Public Mobile representative) for assistance:
