03-03-2019 05:19 PM - edited 01-05-2022 03:34 AM
I'm having difficulty wit my calling can only make out going calls and not receiveing any texts
03-05-2019 02:43 PM
It can be scary when that happens. I just waited for a little while and they started working.
03-03-2019 05:23 PM
@albie74iq wrote:I'm having difficulty wit my calling can only make out going calls and not receiveing any texts
Have you recently ported a number into Public Mobile? Porting in a number can take up to 4 hours if it has been longer than that you should contact the Moderators for assistance. In the meantime you should be able to put your old sim back in to your phone and it should still be active while your port gets completed.
To send a private message to a moderator click this link and describe your issue.
Community Moderators are available from Monday-Friday 9am(Eastern) to 9pm(Eastern) and Saturday, and Sunday from 9am(Eastern) to 7:30pm(Eastern)
03-03-2019 05:21 PM
@albie74iq Did you just port in your number? If yes, it will take a bit to complete. Check your old sim card and see if that still has service.
