Help! Unable to make calls!
Dan-Sweeney
Hey guys,
Ported my number over to public mobile this morning and everything worked fine right off the bat. No trouble sending/receiving calls or texts and connected to the mobile network right away. Then all of a sudden this afternoon I can no longer dial out a call, I keep getting a call failed notification. Any help is appreciated.
Dan
7 REPLIES 7
srlawren
@Dan-Sweeney I'm glad things are working for you now 🙂
Dan-Sweeney
Thanks for your reply,l. I have been in touch a moderator who has been a great help, but unless they have done something behind the scenes my issue seems to have sorted itself out. Go figure
Dan-Sweeney
I did have LTE enabled even though  my plan is only for 3G, but disabling LTE didn't seem to solve the problem either. Strangely enough though it seems to have sorted itself out, and I am able to make calls again. Thanks for your help
srlawren
@twest666wrote:
Is your phone dropping down to 3G/HSPA when making calls? If not may be a setting issue.
@Dan-Sweeney this is a good point raised by @twest666.  Is it possible you have your Preferred Network Type setting set to 4G/LTE only?
twest666
srlawren
@Dan-Sweeney if you haven't already, it wouldn't hurt to try a reboot of your phone to see if that resolves it.  Then reach out to the moderators as @Acekiller suggested if it does not.
Acekiller
you will need the mod to assist you on this.
Sending a message to the mod teams:
In your message include:
- account email address
- PM phone number
- explanation of what is happening or a link to this thread
- if its a porting issue include your sim number, old account name and account number
