03-16-2019 05:26 PM - edited 01-05-2022 06:53 AM
I have a Sim from Travelsim, and Country Code is +372
Estonia
Is it covered under the Global L-D, or NOT?
03-16-2019 07:12 PM
@makkahn28 - in order to use Fongo, they would have to be connected to the internet - either by cell data plan, or wifi.
03-16-2019 07:06 PM
How would Fongo work exactly?
PM being limited, Fongo has No Sim, How can it be used per say?
03-16-2019 06:29 PM
03-16-2019 05:58 PM
Found out that Travelsim's Country Code # are Estonian
What Roaming Sims are competitive?
Roam Mobility is ONLY US/Can
What other exists out there?
03-16-2019 05:39 PM - edited 03-16-2019 05:40 PM
@makkahn28 wrote:@Pizzaeh , My Parents are going on Vacation to Taiwan, Singapore, Malaysia and Vietnam
I know PM has No Roaming beyond the US
The Rates Travelsim have are INSANELY Expensive
If you want to call back to US/Canada in these countries AND you have internet while travelling, try TextNow. They'll give you a free US phone number and you can text/call any US/Canadian number for free (Refer to their rates for calling other countries, can't text other countries). All you need is internet. You can rent a pocket wi-fi if you need it anywhere, compare prices beforehand.
03-16-2019 05:38 PM
Travelsim is what I ordered as my Parents need a Sim for their Vacation
Just saying, No where is cheap
Travelsim uses European Country Code
They're a European Co
03-16-2019 05:36 PM
03-16-2019 05:34 PM
Long Distance Calling
03-16-2019 05:33 PM
The Text rate for Vietnam is like $1.31
Talk is like $0.77 per Min
Data is $0.3 per MB
Taiwan, Text, $0.85 per Message
Talk is $0.85 Per Min
Data same rate
Text for Singapore: $1.31 Per Text
Talk is $0.69 Per Min
Data is same
03-16-2019 05:33 PM
@makkahn28 wrote:I have a Sim from Travelsim, and Country Code is +372
Estonia
Not sure what your Travelsim has to do with Public Mobile, but for the Public Mobile long-distance add-on, but you have to be in Canada, and calling to any of these countries listed. Not what you need, based on your post. Someone can correct me if I'm out in left field.
"400 International Long Distance minutes
Included countries: Canada, China, France, Germany, Greece, Hong Kong, India, Italy, South Korea, Malaysia, Mexico, Poland, Portugal, Puerto Rico, Singapore, Spain, Thailand, United Kingdom, United States, and Venezuela."
03-16-2019 05:32 PM
To reduce costs, cheap carrier doesn't allow roamings. Please explain what is Global L-D?
03-16-2019 05:29 PM
Also, the rates from them are Insane
Really wished PM had their OWN Roaming Packages that covered Vietnam, Singapore, Malaysia, HK, Macau, Japan, Etc, as well as Had their Global L-D Expanded beyond the Infamous 18
