Friend referral
Savebig2
Hey PM!
i did a friend referral couple days and haven’t got the text yet -
my friend and got the $10 credit
1 REPLY 1
dabr
@Savebig2 wrote:
Hey PM!
@Savebig2   You may want to check with the friend you referred that he input the correct referral code.  IIRC usually the text arrives within minutes of a successful referral but if you still don't hear back and it's been 72 hours since the referral, then you may need to submit a ticket to moderators via SIMon ? mark bottom right of your screen and ask what happened, that is if your friend verifies that he used your referral code correctly.  If the friend made an error in the code then they'll also need to ask moderators to correct that error.
