05-21-2020 05:10 PM - edited 01-05-2022 10:51 AM
Does Freedom Mobile's Pixel 2 work on the Public Mobile Network? I'm having difficulty finding the frequency of this phone and Freedom's network to compare it to Public mobile's.
05-21-2020 08:23 PM
05-21-2020 08:21 PM
@rozzyelle I see you already have your answer but just wanted to let you know that the phone I'm using with Public Mobile is a Pixel 2 and I've had no issues. It did not come from Freedom Mobile so I can't talk to that part.
05-21-2020 05:17 PM
Yes @rozzyelle It's 100% compatible it has the required 3g and 4g LTE bands. https://apn-canada.gishan.net/en/apn/public-mobile/google-pixel-2
Here's 4 articles on activation and porting and the Refer a friend reward if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
Welcome to PM. Stay safe.
05-21-2020 05:17 PM
@rozzyelle wrote:Do I need to unlock the Pixel 2 first?
@rozzyelle No, all Pixels are always unlocked.
05-21-2020 05:14 PM
05-21-2020 05:12 PM
@rozzyelle wrote:Does Freedom Mobile's Pixel 2 work on the Public Mobile Network? I'm having difficulty finding the frequency of this phone and Freedom's network to compare it to Public mobile's.
@rozzyelle All Google Pixel's work with Public Mobile. Great phone, will work without any issues.
05-21-2020 05:11 PM
@rozzyelle Yup, it should work fine as it is no different than the one bought directly from Google.
