07-23-2020 08:13 PM - edited 01-05-2022 12:33 PM
My phone number:- 647xxxxxxx
i want to do self serve. I need to recreate my account.
and when now I want to put my public voucher. I does not let me do.
please fix that problem also
thanks
EDIT: ph removed by NDesai
07-23-2020 10:57 PM
07-23-2020 08:18 PM
@Yogesh1 wrote:My phone number:- 647xxxxxxx
thanks
@Yogesh1 hi have you tried forgot password for your account if it won't work
contact a moderator click on the ? Bottom right hand corner Ask Simon to speak to a human this will help create a ticket to speak to a moderator mention forgot password check the envelope top right corner for a reply response time is 2 to 48 hours
07-23-2020 08:17 PM - edited 07-23-2020 08:20 PM
Have you tried the forgot password link?
https://selfserve.publicmobile.ca/forgot-password/
If you don't remember anything about your account you will have to contact the moderators for assistance.
Two ways to reach them
1-
2- via private message at link below.
note . You will have to do number 2 as number 1 you need your account info.
07-23-2020 08:17 PM
@Yogesh1 You can dial 611 to add your voucher. To get your self-serve access back, please check your email accounts for PM welcome email. Once you know your email you used, you can use the Forgot Password tool to reset your password if you remember the answer to the security question. If you cannot do this, you can reach out to the moderator team.
You can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
07-23-2020 08:16 PM
Welcome to PM @Yogesh1 please use the 3 dots on the top right of your post to remove your phone number from the post. This is a public forum. Did you activate your sim instore, or online? Stay safe.
