02-23-2021 05:00 PM - edited 01-06-2022 02:10 AM
My FaceTime calls are lagging. The cellular data is on. This happens using the house Wi-Fi and it's connected. No other incoming calls that are interrupting the current FaceTime conversation. It happens constantly and has been getting worse.
Service
02-23-2021 09:26 PM
@TMK wrote:I am now back on Wifi and this seems to be better. I do have an older iPhone SE which still works great. Our connection speed has been great as I check it often. And hopefully it gets better with the new Fiber Optics.
I have an SE as well. No issues on FaceTime video locally or to Anaheim. Are you using FaceTime audio only and not video?. Have you checked your internet speed and how many curves do you have for wifi? Also fibre optic internet from who?
02-23-2021 05:54 PM
I still have an older SE but have the latest software update.
02-23-2021 05:53 PM
02-23-2021 05:40 PM
@TMK wrote:I'm trying talking on FaceTime without WiFi and so far it's good.
Your home WiFi performance is the problem. Check the connection signal strength, reposition the router if signal strength is low. Consider a mesh network. If signal strength is not the problem, reboot the hardware to see if that helps.
02-23-2021 05:35 PM
02-23-2021 05:33 PM
02-23-2021 05:06 PM
@TMK :Have you already upgraded your phone iOS to latest version? That could help.
02-23-2021 05:04 PM
@TMK :Because not using data and instead using wifi, the problem is either your phone or your wifi speed/connection - nothing to do with your cell service provider.
02-23-2021 05:03 PM
