Expedite a SIM card?
jko1
Is there any way to contact a real person in order to get a SIM card expedited? I would like to use a referral code I have but it expires Oct 31. I would like to get my SIM card before then.
noaccountpls
HI @jko1
there is no way to get a SIM card expedited , I have tried.  Here is what you can do I don't think you can get a refund at this point so here is a link to find a store.
https://www.publicmobile.ca/en/bc/store-locator?ds_rl=1268486&ds_rl=1268486&gclid=Cj0KCQjw48OaBhDWAR...
Amazon was offering same or next day delivery. Not anymore
Meow
There no way to contact PM support - live person.
You can do it Only through personal mail. But I doubt they will be able to 'expedite' your SIM order. If you already ordered, be patient and eventually it should arrive.
Referral codes (from other PM customers) do not expire. Unless you are talking about promo codes...
Try to call Koodo/Telus physical stores in your vicinity to find out if they have any PM SIMs. You can get it that way and keep ordered (when it arrives) as spare. SIMs do not expire 🙂
dust2dust
Click on the Find a store link down below to find corporate stores that should have a sim. Call them to see if they do. When the other arrives use it as a spare for referrals or replacement.
