Esim
Lori1313
I can’t download the eSIM nothing works
Lori1313
I went back to settings since the last response and public mobile was now listed as the carrier and phone seems to be connected to public Servers I still can see the eSIM listed and I can’t find eSIM manager on the this iPhone but all seems to be working!
PM is Public Mobile
Use the link above to message them for help
But you checked your Sim Manager or Settings -> Cellular and you don't see a Public Mobile eSIM there?
Lori1313
Hello. Not sure what PM stands for or how to ask PM there is no eSIM on thr phone and when I try to scan the QR code it says it cant activate
slusagm
If you used the app to subscribe, the app have already installed the PM sim on your phone.  Check your sim manager to see if a PM sim is there
If not there, ask PM to check.
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
