End subscription
Pri2
How to end an active subscription ?
2 REPLIES 2
@Pri2
There are 2 options to close your subscription.
- Port your number out to another carrier and your account will be closed once porting is completed.
- Disable Subscription button in your account and your account will be closed after 90 days of nonpayment.
Customers wishing to not continue with Public Mobile service can disable autopay.  After 90 days of the Public Mobile account being in suspension from a failed renewal will cause the account to be closed.
