10-19-2016 10:28 PM - edited 01-04-2022 03:41 PM
My phone has been working well and suddenly it's showing emergency calls only. Can't call out and receive calls. Pls advise.
10-20-2016 09:34 AM
Of course I can @TC, can you send me your number via private message ?
Thank you 🙂
10-20-2016 09:33 AM
Hi Mary - yes, if you can help me look into it that would be great! thanks.
TC
10-20-2016 09:30 AM
thanks for the advice - i did take the sim card out and put it back. still the same. no change.
i didn't have a chance to try the sim card on another phone though.
10-20-2016 09:29 AM
Hey @TC
Please let us know if you need us to look into this for you.
We would be more than happy to 🙂
Mary
10-20-2016 07:39 AM
10-20-2016 04:49 AM - edited 10-20-2016 04:53 AM
Have you tried rebooting it? I know it's a crappy advice but it might work.
Also, if you go in the settings and try to manually select your network, after it scanned, do you indeed see any network? [If you have an Android phone: go into settings, then cellular netowkr, then Network operator. Let it scan for a while (can be slow) and see if it detects networks, including PM]
10-20-2016 12:48 AM
Hello there. Might be a problem with sim card/smartphone after a drop. Usually pop-up out of the tray. Can you remove the sim and add it back to see if any result ? And restart your phone after.
Also if this doesn't work if possible : can you switch the sim card into another smartphone to see if that get services? If this will work it might be a damaged sim card.
