07-18-2022 11:24 AM
My self serve email is no longer valid hoe can I change it
My Account
07-18-2022 12:16 PM
@Blizzy21 hi contact a cs agent to change email
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
07-18-2022 11:26 AM
The only way is to ask the support people. Click on the chatbot in the footer below. Or if that errors out then you can use the private messaging system.
