12-15-2020 10:42 AM - edited 01-05-2022 04:29 PM
Hi all,
I've recently registered for the Public Mobile's promotion ($5 off and 50% off sim) but the email address I used to registered for promotion cannot be registered because it's over 30 letters.
Does this mean that I cannot receive a promo as I would have to use a different email address?
I received the SIM today and was trying to register but unable to due to the length of the email address. I can use different address but wondering if the promotion will carry over to the new address or it must be the same email address (I am guessing this is the case).
Thank you for your response.
Eric
Joining Public
12-15-2020 12:18 PM
1. Contact Mod team Here MOD TEAM PRIVATE MESSAGE
2. I would suggest copying this post link so they can reference it.
3. They will be able to manually submit email.
Alternate way.
Self Serve Chat Bubble
1.Type Change email
2. enter old email that you used for promotion.
3. Should accept the longer email.
12-15-2020 11:01 AM
Yes, @MoonCakez , that is a known issue that other users have also faced.
Given it's a system limitation on Public Mobile's part, they should be able to rectify it for you. I would certainly contact them as @RossN advises and briefly explain the situation.
Good luck!!!
12-15-2020 10:52 AM
@MoonCakez wrote:Hi all,
Eric
@MoonCakez send a private message to the Moderators by clicking here.you should get a response between 2 to 48 hours a reply should show up in your little envelope in the top right corner,
