08-19-2026 05:09 PM
I purchased my subscription with esim. Unfortunately, ESIM did not get activated and I've been trying everything I can to activate the Esim (resetting network, turning off original esim, etc). I tried to contact support through messaging and chat but neither seems to work.
08-19-2026 05:19 PM
You removed the old sim or one esim?
PM sim is enabled and set as Primary?
If you want PM to check again , Simply open ticket with PM using Expert Messaging. Click the Orange Chatbot icon on the lower right to start, or use this link https://widget.telus.tiia.ai/libs/chatbot.html?botId=ZJkWuVb7Hp6EEcTIZKMZbvLwuDV&lang=en&toggle=fal...
(For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.)
PM will reply you via Expert Messaging between 9AM-10PM EST (Mon-Sun)
(for help with Expert Messaging, check here: https://publicmobile.ca/en/get-help/articles/expert-messaging )
08-19-2026 05:19 PM
Seems you tried everything.
So your not able to create a ticket through the chatbot or rhe Message Centre now located in the My Account tab?
The below was recently introduced on how to contact them.
