03-28-2020 06:11 AM - edited 01-05-2022 10:06 AM
03-28-2020 09:49 AM
It's basically always been the same on all Android devices. "About" in Settings, click on "Version" or "Build" many times. (Sometimes one click per Android generation, sometimes a countdown is shown on screen).
"Developer Options Enabled" or some kind of easter egg graphic will inform you of success. Additional clickings or combinations can then reveal other hidden easter eggs (photo albums, mini-games, etc) - the big OEMs like Samsung always put something undocumented in their ROM to "encode" it against piracy.
Developer Options itself is usually a tick box or submenu somewhere in Settings.
03-28-2020 06:14 AM
Go to the settings app and click on "About phone", and then "Software information". Click on "Build number" until it says you are a developer. Now you can find developer options at the bottom of the settings app.
