Data
bryann112
Under data used in some places there is only a 1 is that 1mb
The "1" only means one MMS message. It isn't an amount of data.
t_p
@esjliv wrote:
@bryann112
When sending or receiving an MMS text, this is what will be displayed in your data usage history.
NOTE though, MMS does not count towards you Data Plan or Addon allotment. But MMS does need to be enabled to use this feature.
@esjliv  you mean data does need to be enabled to use this feature.
@bryann112
NOTE though, MMS does not count towards you Data Plan or Addon allotment. But Data and MMS does need to be enabled to use this feature.
t_p
That's correct.
EDIT: I didn't see the tag about mms when I replied to OP.
For mms, see @computergeek541 's explanation below.
