Data start date
UrbanArt
I am not sure what is going on with two of my plans, I have a due date on the 13 of 14th of the month usually but it seems my data is not resetting. I looked at my data usuage and it seems to  not have reset and is causing my issues on one account. If I have used my data it is one thing but I have no idea why it did not reset on the day it should have. How do I get this looked into?
Michael77
Is this resolved?
Acekiller
Hope you get your issue fixed soon!
UrbanArt
Thanks I contacted the mod team for help so thanks for the reply though.
Brandonlelievre
A little more info is needed to help you. What data is included in your plan. Is it drawing from data that was part of the November sign up promo? Or is it drawing from your plan data. Either way you will need to contact a moderator to sort it out we can only help you so much
mimmo
are you on a 3g plan?
Contact the Moderator_Team by clicking here.
In your message include:
- account email address , pin number if possible
- PM phone number
- explanation of what is happening or a link to this thread
- if its a porting issue include your sim number, old account name and account number
