Data overage ? Or does it stop ?
11-26-2018 07:48 PM - edited 01-05-2022 02:36 AM
11-26-2018 09:27 PM
@Addicted2fishin, the other members have pretty much given you the answer to your question. I just want to add that when your data is used up, you will see that in the self serve overview in the form of missing information on the data usage. This is the quirk in the system. Instead of showing 100% data usage, the data usage is removed. Many customers who use up their data ask about why they can no longer see it in the self serve. This is the reason.
11-26-2018 08:01 PM
It does. Thank you very much. This place is pretty neat! Faster than customer service at bell!
11-26-2018 07:59 PM
@Addicted2fishin wrote:Hey folks. Brand new here. What happens in the event of a data overage ? Do I get charged more? Do they cut me off?
Also, I signed up for 3G but at the top will still say LTE.
Hi there and welcome! You can’t have a data overage as you have prepaid for a certain amount of data. Once it has been used, you will no longer be able to access the internet until your next payment cycle or you buy additional data.
PM provides you with an LTE network with speeds throttled to 3G, so you will always see LTE on your device.
Hope per this clarifies for you.
11-26-2018 07:54 PM - edited 11-26-2018 07:54 PM
Once youve used it is finished...you can buy xtra via an add on but expensive...as for the 3g, from what ive read here its actually lte lite...and actually works quite well
