Data not working
ChuckR49
I recently switched phones.  My data was working fine before I switched.  My data is turned on and there is no data limit set but data does not work.
popping
@ChuckR49
Are you using a LG phone?
If yes, you need to do a network reset after changing to different provider before getting your data working.
Perform the network with your PM SIM card inserted.  Re-start your LG phone. It will setup your APN automatically.  If not, manually setup APN as per above posts in this thread.
toxicfire
@ChuckR49 check your APN settings.
Depending what phone your using.If android usually found here
settings-connections-mobile networks- APN (access point name) then in there check the settings
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Leave blank
APN type: Leave blank
geopublic
@ChuckR49  Compare the APN settings from your old phone with your new phone. Just make sure the APN settings are correct and/or not missing on your new phone. What is the make and model of your new phone?
ShawnC13
Have you checked your APN settings on the new phone?  Is it a brand new phone as well or did you buy it from someone
Here is a great site to setup your APN and instructions on how to do it.  Find the APN Settings for Public Mobile here!
