Data not working
aascvd01
I have a plan with 1 GB of data. When I have full bars of 3G, nothing loads still...
2 REPLIES 2
geopublic
@aascvd01  what's the make and model of your device?
goldilock
@aascvd01
When you go into your account and plan, does it show you have a plan with 1GB data?
If you check usage, did you use up your data already?
Make sure in your phone's settings that your cellular data is turned on.
Check the apn settings on your phone are:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,agps,supl,fota,hipri,dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
More info for particular devices:
https://apn-canada.gishan.net/en/apn/public-mobile
Please post if this resolved the issue.
