08-22-2026 08:14 PM
I just switched to PM and my data keeps turning off. When I turn airplane mode on then off again the data comes back on. I have iphone15 and APN is isp.
08-22-2026 08:20 PM
Make sure old provider sim is removed, or disable old provider eSIM. And PM sim needs to be enabled and set as Primary.
Then, Reboot phone and Reset Network Settings
Last, ask PM to help and check
Simply open ticket with PM using Expert Messaging. Click the Orange Chatbot icon on the lower right to start, or use this link https://expert-messaging.publicmobile.ca/guest/chat/
(Use your Community account to login. For 2FA, you might need to use email to receive if you cannot receive the text on the phone.)
PM will reply you via Expert Messaging between 9AM-10PM EST (Mon-Sun)
(for help with Expert Messaging, check here: https://publicmobile.ca/en/get-help/articles/expert-messaging )
