Data not right
Dnop68
Plan expired Mar 31 but shows 3.8 g out of 5 used btwn Apr 1 and 31??
Jackhyf63
The fact that your phone number is still working and that you're seeing Plan Expired suggests that date is your renewal.Don't touch anything. Your data may just be coincidental with near the end of your term.
RobertQc
@Dnop68  Where do you see 3.8/5? Plan expired is your renewal day?
geopublic
Did you purchase a data add-on by any chance?
Dunkgirl
@Dnop68  Is tonight your renewal? If so it ok to say expired and your renewal will proceed as normal tonight / tomorrow morning.
srlawren
@Dnop68 can you take a screen shot of the lower half of your Overview page in self-serve and post it here please?  Specifically I'm looking for just this part, but if you are including more of the page, please be sure to blank out any persona info (name, phone number, account number)
EDIT: I suspect this is related to and possibly caused by your other issue.  Your data should reset once the plan actually renews.  You may need help from the moderator team to get it back up and running.  If so, please see here:  How to Get Help
