03-03-2019 06:14 PM - edited 01-05-2022 03:34 AM
Just purchased SIM and signed in. Data is not working! Used the Android ASN as there was not a custom ASN for Poloroid A600. Plan had 500GB + 500GB for Autopay)
Please Help!
My Account
03-03-2019 07:27 PM
It Worked!
Difference was the following were not set
MVNO type: GID
MVNO value: 4D4F
Thanks!!
03-03-2019 06:23 PM
@Sprackmd wrote:Just purchased SIM and signed in. Data is not working! Used the Android ASN as there was not a custom ASN for Poloroid A600. Plan had 500GB + 500GB for Autopay)
Please Help!
Find your phone on this list:
Officially Recognized APN Reference
If your phone isn't there maybe these might work:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
