Data issues
06-03-2017 10:11 AM - edited 01-04-2022 01:50 PM
06-05-2017 04:06 PM
I asked @Dieden55 for make and model on Friday and has not responded. This is definitely useful information. However, he or she has posted after that they they tried their SIM in two other unlocked phones and also had no luck with data. This likely indicates a faulty SIM card or an account issue. @Dieden55, have you contacted a community moderator (Public Mobile support employee) via private message yet? They can check your account and if all looks good there, send you a new SIM card free of charge.
06-03-2017 09:57 PM
@Dieden55, sorry to hear about your troubles. You can't blame the service for what is pretty much a user error. Others on this service are able to set up their phone to receive data. If you cannot get it done yourself, you cannot blame the provider. This is a no frills, self serve service. The community here is very helpful. So, if you can describe in greater detail what setting you have on your phone, maybe include some screen shots, we will try to help you through the difficulties.
06-03-2017 07:54 PM
Hi @Dieden55,
Sorry to hear about your trouble. If you can please provide some more information such as:
- the phone you are using
- what apn settings you have entered
- what troubleshooting you have done so far
This will help community memebers to try helping you reslove your problem.
Thanks
06-03-2017 11:12 AM
Remove your sim turn off phone insert sim and restart.
If you using iPhone try network reset option by going setting general scroll down all the way and reset its usually fix iPhone issue. If not then fullbackup and go for factory reset.
For android update us model and make we can suggest according to make and model.
Also try your sim in other phone if available to check if its service or hardware issue.
If nothing help then send a .msg to mod they will look after you
But try those suggestion
Contact any moderator by private message to help you with the process.
In your private message the following info
* PM account email address
* PM phone number
* Detailed explanation
Here is the link for how to contact moderators http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updiated-Contacting-our-Community-Moder...
What you do click on link the webpage will open. You will see a mod team click on any name then scroll down all the way and click on send a private msg then explain your problem
Thanks"
06-03-2017 10:54 AM
data works. as long as you have purchased it in your plan.
what phone are you using? if its an LG g4 or g5 you might need to do a factory reset. iphone4 you need to get seting from a website and uploa a config file.
sometimes you need to delete all past apn setting put in the new apn and reboot the phone.
have you tried your sim in a different phone?
