06-19-2018 09:48 PM - edited 01-05-2022 04:57 AM
I’m just wondering if Public Mobile sends out text notifications if you hit 80% data, etc., like some of the other companies do? And is there a way to put a limit on your own data use? For example, if I have a 90 day plan with 16GB can I limit monthly use to 5GB using the self serve system? Or is this a phone dependent internal moderation?
I would appreciate any help on the topic, thank you!
Service
06-22-2018 07:58 PM
And it shows right under the cellular button how much data you used
06-20-2018 03:47 PM
@tylah wrote:Thank you, it is just a shame that Apple doesn’t allow for a phone specific data limiter. That is one feature I am envious of for androids.
@tylah unfortunately I can't help with the Apple side of the world.
If anyone on Android is looking for a daily limiter, check out Google's own Datally: https://play.google.com/store/apps/details?id=com.google.android.apps.freighter&utm_campaign=website... I looked at it when it first came out and passed on it, but they've added a bunch of stuff lately so I'm test driving it again as of yesterday. One of those features is the ability to set yourself a daily data cap (e.g. if you have 12 GB of data and a 90 day play, you could set 12 * 1024 / 90 = 136.5 MB daily cap. Another cool recent feature is it can show you a list of all the apps you haven't used in ages that is still using data in the background (already identified a few I can turf.)
06-20-2018 03:34 PM
They send out a 75%, 95% and 100% data usage texts.
06-19-2018 10:02 PM
iPhone just limits too many things
06-19-2018 10:00 PM
06-19-2018 09:57 PM
The text is sent when you use 75% and 95% of your data.
06-19-2018 09:51 PM
@tylah, this is the knowledge base on managing your data usage.
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Managing-your-data-usage/ta-p/152760
